Do Disks Break/bend Easily?
Blake
Hello all,
I was talking to my friend today about brakes and he mentioned that disks can easily break. He went on and said that if you mess up a side hop and tap the disk it can break and then you have to pay £20 for a new one. I had never even considered this and wondered if it was true or not.
Cheers,
George
  • Like 1
Noo it'l be fine as long as you get a decent disk brake rotor.
A few years back I had rear disk and used to land on loads of times, most that happened was that it just got a little bent.
Little play with an adjustable spanner and you can easily bend them back (Y)
EDIT: I just got you validated happy.gif
Edited by Jamie_Trials
CHEERS FOR THE VOTE! :
Yay, thanks dude, now I can get a bike on this site. and thanks for the disk brake advice :)
Im sidehopping to left and hit my discs a couple of times , it bends not very easilly and there is no maintenance for disc, for rimbrakes there's a lot of maintenence , you must keepyour brakesystem clean , grinding your rims , and your rims are getting ugly from it , and your rims are getting faster damaged. The grinding makes your rims thinner thinner thineer , and you have to grind your rims weekly
And a cracked disc costs 30 a rim 50 to 60 ;)
I hope that you've enough information now :P
Edited by Jason Maarsseveen
1. there is maintenince for discs not too much.
2. you have to keep your disc clean and rim grinding is optional you dont HAVE to have it.
3. a cracked disc can be as low as 10 second hand and a good rim is only 30 new so about 15 second hand.
Learn something new everyday :king:
