Cranks
crashbanggg
Well... There's a few things to know.
You'll hear about "square taper", and "ISIS" cranks. This refers to the system used to mount them on to the bottom bracket. If you have a square taper BB, obviously you need square taper cranks. ISIS is supposedly stronger interface, and quite often easier to get off, but I've never had a problem with square tapers. The tapers can die after a while however, and I think there's more choices with ISIS, so if you're starting from scratch I'd recommend ISIS.
Next is the length. The longer the crank, the more leverage you get on the drivetrain. Whilst it won't change the amount of gear-inches you get, longer cranks will make a certain gearing feel easier to pedal than shorter ones. There's no right or wrong - it's all your personal preference. If you have an 18:12 gear ratio and 158mm long cranks and it feels too heavy, but 18:13 with 158mm cranks feels too light, you could try an 18:12 ratio with 165/170/175mm cranks. Over time you'll find out what you like.
Finally, most trials-specific cranks can take a front freewheel. If it has threads on the driveside crank, it can take a freewheel. If it has anything to do with bolts, or "arms", it can't.
Edited by aener
