Disk Or Hydrolic Vee
blaney09
I have the same bike i run a maggie now would nevr look back to be honest
Give it a try
i used to run front and rear maggie on my onza t-bird and ther where pretty good. i was just wondering which is better and i think i will change to rear maggie as i like the look of the 2011 model. thanks for fast replies :)
I'm guessing it's a cable disk then
either a hydraulic disk or a magura would beat it, so take your pick I guess
get a magura with some decent pads and a grind, you're sorted
yes they are cable disk thanks for the fast replies and i think i will go for the 2011 hs33. :)
if your looking for a cheaper option maybe try a bb7 ?
are they any good because the brakes on my bike are terrible the pads need ajusted like every 5 mins' its really annoying, thanks
2011 HS11 is cheaper, but works exactly the same as the 2011 HS33 (Y)
thanks i will consider getting a hs11 :)
try bb7s there awesome! and if it's not for you they aren't hard to sell on cause everyone else loves them...
i might get a bb7 for the front what size disk would you recomend for a 20" wheel ???. thanks :)
If your already running cables then I'd say try a BB7 before anything else, your already setup in terms of lever and cable so just need the caliper and if you don't get on like ogre says it'll easily sell.
(Y)
Its a much cheaper swap over. Look at www.wiggle.co.uk and see if they've got the cheapest BB7 on the net atm ;)
