Blake Posted October 7, 2010 Report Share Posted October 7, 2010 Hello. I've read a lot on this website that a well set up and well maintained V brake can often be as good or even better than a hydraulic rim brake. I Was just wondering, is this true and if so how can I keep my V brakes (on my mountain bike, haven't got a trails yet!) well maintained. Thank you George P.S. Votes are appreciated, sorry to mention it but this is my fourth topic and i've posted lots of comments and still not had a single vote! Quote Link to comment Share on other sites More sharing options...
Rowlly21 Posted October 7, 2010 Report Share Posted October 7, 2010 Yes Good leaver -SD7 Cable-linear Avid arms Decent set of pads Youll be singing Quote Link to comment Share on other sites More sharing options...
tdubz Posted October 7, 2010 Report Share Posted October 7, 2010 yeah can somebody recommend the best cable both inner and out to use? thanks Quote Link to comment Share on other sites More sharing options...
Rowlly21 Posted October 7, 2010 Report Share Posted October 7, 2010 http://www.trials-forum.co.uk/index.php?showtopic=155028&st=0&p=2172016&hl=linear&fromsearch=1&#entry2172016 Take a look at that Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted October 7, 2010 Report Share Posted October 7, 2010 Just keep everything well lined up and lubed from time to time and you can't go far wrong. A decent linear outer will do it the world of good, as will a clean rim with pads set up squarely. The inners aren't so important, but before fitting any spray some lube (TF2 etc) down the outers and give the inner a light greasing to keep things as frictionless in there as possible. Let off all tension from the springs, set up the cable length then apply just enough tension to centre the brake and give the desired lever feel. Kept my brakes working flawlessly for years on the trials bike, so should do the job for you Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted October 8, 2010 Report Share Posted October 8, 2010 Vee's when set up correctly are way better than maggies, imo, dont forget a booster though, it increases hold by a massive amount. Quote Link to comment Share on other sites More sharing options...
