trials4life1 Posted October 3, 2010 Report Share Posted October 3, 2010 well basically i have put a new trialtech chain onto my bike. it fits snug and everything but there is a problem, when i pedal it makes a noise asif its going to come off, or it sounds like the bottom bracket. but i dont think it wll be the bottom bracket because it didnt do it with my old chain. it doesnt do it when the wheel is spinning with the freewheel going on its own. its only wheni pedal any ideas? please help. thanks. Quote Link to comment Share on other sites More sharing options...
steve g Posted October 3, 2010 Report Share Posted October 3, 2010 well basically i have put a new trialtech chain onto my bike. it fits snug and everything but there is a problem, when i pedal it makes a noise asif its going to come off, or it sounds like the bottom bracket. but i dont think it wll be the bottom bracket because it didnt do it with my old chain. it doesnt do it when the wheel is spinning with the freewheel going on its own. its only wheni pedal any ideas? please help. thanks. I had the same problem, it was a worn sprocket causing it, so i recommend you replace yours. :/ Quote Link to comment Share on other sites More sharing options...
WIGAN ?? Posted October 3, 2010 Report Share Posted October 3, 2010 have a look at your chain line too if its miles off your chains gunna be clunking onto the sprocket rather than smoothly slipping over it Quote Link to comment Share on other sites More sharing options...
trials4life1 Posted October 3, 2010 Author Report Share Posted October 3, 2010 the sprockets got all the teeth and none of them are worn. thanks mate. the chain line looks straight to me. any other things it could be. thanks Quote Link to comment Share on other sites More sharing options...
Mikee Posted October 3, 2010 Report Share Posted October 3, 2010 Could it being too tight be a possibility? Or could It be the new chain bedding into the old sprockets? That's the only things I can think of that hasn't already been mensioned. Quote Link to comment Share on other sites More sharing options...
trials4life1 Posted October 3, 2010 Author Report Share Posted October 3, 2010 Could it being too tight be a possibility? Or could It be the new chain bedding into the old sprockets? That's the only things I can think of that hasn't already been mensioned. i was thinking if it was bedding in. im going to service it tomorrow to try and figure it out. lets hope its just wearing in. thanks lads Quote Link to comment Share on other sites More sharing options...
trials owns Posted October 3, 2010 Report Share Posted October 3, 2010 i had this, i sprayed silicone spray in the freewheel and it stopped the noise, if not im betting on the chain being to tight. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted October 3, 2010 Report Share Posted October 3, 2010 You're really supposed to replace the chain and sprockets together, as they all wear down with eachother. Putting a new chain on worn sprockets will just wear the chain down quickly to suit the sprocket wear. If you replace them all at the same time, they all wear down with eachother and last a lot longer! Obviously it's way more expensive, and a lot more work, but it's better in the long run... Quote Link to comment Share on other sites More sharing options...
