Urgent Question.
trials owns
hi there,
looking at a echo tr rear hub but i want to run this on my onza t bird with chain tugs, but i dont know if i can run it with chain tugs as they are meant for snail cams.
so can i?
cheers
Em, you probably can run them wit chain tugs. You could just drill holes into your frame at the exact right point and then tap them i think its called to put threads into it, Chain tugs probably will work though.
