SamKidney Posted September 28, 2010 Report Share Posted September 28, 2010 Hi all, I've just bought the 05 lever body off tartybikes and as it says I have to use my exsisting Piston and spring from my snapped 05 but the thing is, how do I remove it and fit it on the new lever body! Please help as this is preventing me riding and I'm goin on a b-day ride on saturday and dont want to miss out Thanks Quote Link to comment Share on other sites More sharing options...
trials owns Posted September 29, 2010 Report Share Posted September 29, 2010 have you just got a casing if so, take the lever of with tpa on it, you will see a piston take that out (it should just come out, if not undo the screw under where the hosing enters the lever and push something thin and small through) then a biggish spring. now putting it in is backwards in the new casing, spring-piston-lever with tpa in. job done then just bleed, its all fairly simple. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted September 29, 2010 Author Report Share Posted September 29, 2010 thanks mate Just had a look and the designs so simple, I might machine my own lever body and use the magura lever and piston Quote Link to comment Share on other sites More sharing options...
isitafox Posted September 30, 2010 Report Share Posted September 30, 2010 thanks mate Just had a look and the designs so simple, I might machine my own lever body and use the magura lever and piston Would be interesting to see, just a case of making sure it seals properly! Quote Link to comment Share on other sites More sharing options...
SamKidney Posted September 30, 2010 Author Report Share Posted September 30, 2010 would be stronger than the cast lever body too. Ive just been given permission to use the milling machine and lathe at school to sculpt and bore the cylinder too. Would also count towards my Gcse in metal work Quote Link to comment Share on other sites More sharing options...
isitafox Posted October 1, 2010 Report Share Posted October 1, 2010 Get it made, then make a load more to sell on here!! Quote Link to comment Share on other sites More sharing options...
SamKidney Posted October 3, 2010 Author Report Share Posted October 3, 2010 will try lol, figured it out and if I worked non stop it would take about 1 hour per lever body to machine then, 20 mins for finishing and tapping out bolt threads. Then you can use your magura piston, spring, lever and TPA. Allong with shroud nut and bleed bolt. Quote Link to comment Share on other sites More sharing options...
