t-comp-kierz Posted September 27, 2010 Report Share Posted September 27, 2010 Every time a pedal I hear a creaking sound coming from my bb (I think) its really starting to get on my nerves Does anybody know what the problem is or how to fix it ? Quote Link to comment Share on other sites More sharing options...
isitafox Posted September 27, 2010 Report Share Posted September 27, 2010 At a guess I'd say it's either a bit loose and/or needs a good grease up on the BB threads and the spindle. Quote Link to comment Share on other sites More sharing options...
samster Posted September 27, 2010 Report Share Posted September 27, 2010 tighten up your crank bolts as much as you can. Quote Link to comment Share on other sites More sharing options...
craigjames Posted September 27, 2010 Report Share Posted September 27, 2010 Take off the cranks and take the bb out fo the frame, clean all the threads and grease them up, torque it up in the frame. If it's ISIS, clean and grease the splines on the bb and cranks and then tighten to the correct torque. If it's square taper then clean the tapers on the bb and cranks, DON'T grease them and tighten them to the correct torque. Quote Link to comment Share on other sites More sharing options...
t-comp-kierz Posted September 27, 2010 Author Report Share Posted September 27, 2010 Take off the cranks and take the bb out fo the frame, clean all the threads and grease them up, torque it up in the frame. If it's ISIS, clean and grease the splines on the bb and cranks and then tighten to the correct torque. If it's square taper then clean the tapers on the bb and cranks, DON'T grease them and tighten them to the correct torque. Why not? Quote Link to comment Share on other sites More sharing options...
