Rear Disk On Mod
t-comp-kierz
10 members have voted
  1. 1. Rear Brake
    • Rear Disk
    • Or Rear Maggie
Im thinking of going double disk as my maggis is just a hassle (N) What are the pros/cons of going rear disk? And which is better Hope mono trial, Try all or the magura louise?
I would suggest mono trial. the try-all is just a re branded mono trial..
as said down side you can bend rotors
up side, they work in the wet, make less noise...
Do you get better hold/bite than a maggy?
Definitely better hold, by miles! The bite's sorta... different. You definitely have to get used to the feel of it 'cos it does feel completely different to a Magura, but once you're used to it it's amazing.
In my opinion the modulation on the rear is not such a good thing.
I prefer a good V for the on/off'ness
For natural and tech stuff the modulation is good because you still get the bite/hold you need, but for pure TGS street a rim brake might work a little better.
Didn't bend a rotor once when I used rear disc. I only used a 160mm though so it was nice and tucked out the way. If you get a Mono Trial, you'll only need 160mm anyway...
Disc's are brilliant , i use the tryall disc brakes , bending rotors isnt a thing that always happens , but im left footed.
If your disc is set up shit like crap bleed and so on your disc will work poo , if you set up good the disc will be fine , bitey , holdy , strongy.
you can have a really good magura set up which kicks disc ass!
