Cundog123 Posted September 23, 2010 Report Share Posted September 23, 2010 Hi, i have a problem with my maggie, whenever i set up my pads perfectly square i pull in the leaver like twice and the one pad goes back in its normal place and touches the rim and rubs, any ideas what to do thanks matt Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted September 23, 2010 Report Share Posted September 23, 2010 Hi, i have a problem with my maggie, whenever i set up my pads perfectly square i pull in the leaver like twice and the one pad goes back in its normal place and touches the rim and rubs, any ideas what to do thanks matt Tighten your wheel bolts, it may be moving the wheel to one side. When your pads are perfectly square make sure your clamps are extremely tight. Should do the job... Quote Link to comment Share on other sites More sharing options...
Cundog123 Posted September 23, 2010 Author Report Share Posted September 23, 2010 wheel bolts are tight and so are the mounts Quote Link to comment Share on other sites More sharing options...
josh barker Posted September 23, 2010 Report Share Posted September 23, 2010 When your pads are perfectly square make sure your clamps are extremely tight, then f**k up your theads in the frame no need to make them extremely tight. what clamps are you using? is your tpa wound out? one of your pistons could have a sticky piston or your brake could even have air in it Quote Link to comment Share on other sites More sharing options...
Rob. Posted September 23, 2010 Report Share Posted September 23, 2010 Tighten your wheel bolts, it may be moving the wheel to one side. When your pads are perfectly square make sure your clamps are extremely tight. Should do the job... Make sure you dont over tighten otherwise you'll just bugger up your threads! Quote Link to comment Share on other sites More sharing options...
Cundog123 Posted September 23, 2010 Author Report Share Posted September 23, 2010 (edited) there cant be no air in it because i have only just bled my brake, what do i do if i have a sticky piston Edited September 23, 2010 by Cundog123 Quote Link to comment Share on other sites More sharing options...
josh barker Posted September 23, 2010 Report Share Posted September 23, 2010 there cant be no air in it because i have only just bled my brake, what do i do if i have a sticky piston i put a drop of magura royal blood on the piston. easy way to do it= press your lever and then put 1 drop on it. it might just need pressing and then the piston ramming back in Quote Link to comment Share on other sites More sharing options...
Cundog123 Posted September 23, 2010 Author Report Share Posted September 23, 2010 ok ill try that thanks matt. Quote Link to comment Share on other sites More sharing options...
trials owns Posted September 23, 2010 Report Share Posted September 23, 2010 hub bearings? Quote Link to comment Share on other sites More sharing options...
Cundog123 Posted September 23, 2010 Author Report Share Posted September 23, 2010 i put some tape under the rubber seal so now it doesnt come in as much but i think i will do something with my pistons, thanks for the comments matt. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted September 23, 2010 Report Share Posted September 23, 2010 Hi, i have a problem with my maggie, whenever i set up my pads perfectly square i pull in the leaver like twice and the one pad goes back in its normal place and touches the rim and rubs, any ideas what to do thanks matt Change to vee's Quote Link to comment Share on other sites More sharing options...
Cundog123 Posted September 23, 2010 Author Report Share Posted September 23, 2010 i suppose it would be less hassle, what are your vee's like Quote Link to comment Share on other sites More sharing options...
aener Posted September 23, 2010 Report Share Posted September 23, 2010 (edited) Change to vee's No - don't. If you're having trouble setting a magura up to work right - chances are you'll have even more of a bad experience trying to set up vees to work as effectively. They work just as well, but can be a right old fanny to set up so they do. Sounds like you just need to put more electric tape under the rubber ring. They squish down after a while, so you either need new ones, or to beef it out paper/tape. Edited September 23, 2010 by aener Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted September 23, 2010 Report Share Posted September 23, 2010 wheel bolts are tight and so are the mounts Give your mounts/callipers a wash might be oil on them. does it need a bleed? is your tpa in/out what mounts do you have? are you using the plastic washer? has the plastic washer got oil on? when you pull the brake watch the brakes do what they do then you'll know the problem I havn't read the thread so sorry if some of these ideas have already been posted Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 23, 2010 Report Share Posted September 23, 2010 The cylinder washers deform over time, and that means that when you try and set your brake up it'll 'pop' back into it's old position. Quote Link to comment Share on other sites More sharing options...
