ryanc Posted September 22, 2010 Report Share Posted September 22, 2010 What is the best type of hydraulic brake to buy Quote Link to comment Share on other sites More sharing options...
montyFORlife Posted September 22, 2010 Report Share Posted September 22, 2010 What is the best type of hydraulic brake to buy Magura hs33 is very reliable and cheap. Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted September 22, 2010 Report Share Posted September 22, 2010 depends if you want a rim brake or disc for disc, id recommend a hope mono trial or magura louise both are really sharp and good modulation ,for a hydro rim brake theres nothing better than a magura hs33 or hs11 Quote Link to comment Share on other sites More sharing options...
ryanc Posted September 22, 2010 Author Report Share Posted September 22, 2010 Cheers what kind of pads do u recomend to buy for them because i have heard maggie blacks are not that good Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted September 22, 2010 Report Share Posted September 22, 2010 loads of people love heatsink yellow, i like superstars red pads but it depends on your rim surface if its ground or smooth Quote Link to comment Share on other sites More sharing options...
ryanc Posted September 22, 2010 Author Report Share Posted September 22, 2010 Smooth rim might get a grind not really sure at the moment Quote Link to comment Share on other sites More sharing options...
montyFORlife Posted September 22, 2010 Report Share Posted September 22, 2010 Cheers what kind of pads do u recomend to buy for them because i have heard maggie blacks are not that good try all croco are good if you have got a grind Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted September 22, 2010 Report Share Posted September 22, 2010 Smooth rim might get a grind not really sure at the moment yeh you should get a grind they are good, wear the pads alot faster but better braking performance Quote Link to comment Share on other sites More sharing options...
ryanc Posted September 22, 2010 Author Report Share Posted September 22, 2010 If i get a grind ill give them a try Quote Link to comment Share on other sites More sharing options...
montyFORlife Posted September 22, 2010 Report Share Posted September 22, 2010 Cheers what kind of pads do u recomend to buy for them because i have heard maggie blacks are not that good Yeah like riding brakeless in the wet Quote Link to comment Share on other sites More sharing options...
ryanc Posted September 22, 2010 Author Report Share Posted September 22, 2010 To of my mates have a grind they are using magura hs33s with heatsink yellows with cnc backings and they get a good hold Quote Link to comment Share on other sites More sharing options...
montyFORlife Posted September 22, 2010 Report Share Posted September 22, 2010 To of my mates have a grind they are using magura hs33s with heatsink yellows with cnc backings and they get a good hold 1.grind your rim 2.dig a bit of tar of the road 3. get some cnc heatsink yellows 4.put the tar on the rim just a little that and you got a amazing brake oh get a light grind fo heatsink Quote Link to comment Share on other sites More sharing options...
ryanc Posted September 22, 2010 Author Report Share Posted September 22, 2010 Cheers ill put the tar on my self or try get one of my mates to do it cause they are good at putting it on Quote Link to comment Share on other sites More sharing options...
montyFORlife Posted September 23, 2010 Report Share Posted September 23, 2010 Cheers ill put the tar on my self or try get one of my mates to do it cause they are good at putting it on all you do is rub it around your rims Quote Link to comment Share on other sites More sharing options...
ryanc Posted September 25, 2010 Author Report Share Posted September 25, 2010 Thanks for the advice Quote Link to comment Share on other sites More sharing options...
matt.price Posted September 25, 2010 Report Share Posted September 25, 2010 hey dude had my tnn belaeys for a few days and they're awsome.. great hold and surperb bite ! added abit of tar for sound and ive got myself the perfect brake Quote Link to comment Share on other sites More sharing options...
Azarathal Posted September 26, 2010 Report Share Posted September 26, 2010 For the guys that said to put tar on a grind, don't, that'll just make your brake worse. Quote Link to comment Share on other sites More sharing options...
matt.price Posted September 26, 2010 Report Share Posted September 26, 2010 disagree. but a tiny bit of tar on my grind and just gave it that little bit of an edge Quote Link to comment Share on other sites More sharing options...
ryanc Posted October 18, 2010 Author Report Share Posted October 18, 2010 I put tar on my rims the other night and my brakes are now amazing. Quote Link to comment Share on other sites More sharing options...
Ali C Posted October 18, 2010 Report Share Posted October 18, 2010 1.grind your rim 2.dig a bit of tar of the road 3. get some cnc heatsink yellows 4.put the tar on the rim just a little that and you got a amazing brake oh get a light grind fo heatsink may as well not run a grind if you want to use tar, also may as well just get the cheapest pads you can buy if you want to run tar. Just grind, it's just better than anything else. I am using tnn LGM pads on the lightest grind you have ever seen (I just scratched my rim with the grinder, you can still see smoother parts that didnt get touched) and my brake is REALLY good, infact it's too loud for me. Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted October 18, 2010 Report Share Posted October 18, 2010 For the guys that said to put tar on a grind, don't, that'll just make your brake worse. No it wont. I put tar on my grind as a last choice as my brake wasnt too good and it is unbelievable. Ryan, new pads as your pads are unknown if we're honest here! Quote Link to comment Share on other sites More sharing options...
Ben John - Hynes Posted October 18, 2010 Report Share Posted October 18, 2010 People who set out to make a good brake by grinding then tarring are just idiots. You're killing your rim AND making the brake worse in the wet. Either grind so it works in the wet, or tar so your rim lasts. Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted October 19, 2010 Report Share Posted October 19, 2010 People who set out to make a good brake by grinding then tarring are just idiots. You're killing your rim AND making the brake worse in the wet. Either grind so it works in the wet, or tar so your rim lasts. I put both on 'cos I don't ride in the wet. Quote Link to comment Share on other sites More sharing options...
Leistonbmx Posted October 19, 2010 Report Share Posted October 19, 2010 Grind it so its rought and then tar, fills in the grind. Pointless. Quote Link to comment Share on other sites More sharing options...
