Tyre Size Help
isitafox
I'm looking at getting some new tyres for my control as I'm still running my old irc's from years back. The problem is the kujo on the rear looks quite tight in the frame and thats only a 2.35 whereas I'm thinking of getting the try all stiky for the rear which is a 2.5.
I know tartybikes has an image showing the measurements of the tyres width and height but thats on a 47mm rim and mines only a 44mm so I'm not sure how far out the measurements would be on my rim.
Any advice?? And before people say get a conti the reason I'm after some try alls is cause of the cheap offer tartys has on them!
Should be about 2mm difference or so (narrower, obviously). Probably less...
