Beeding Hope Brakes.
Laurence--Trials
Alot of people know.. on the Hope Reservoir caps it says 'only bleed with Dot 4 or 5.1' Why is this? because im wanting to bleed my brake and its a pain in the arse to do because im not fantastic at it and i normally end up getting fluid like everywhere.. so i was wondering why we cant bleed them with water?
EDIT: and i dont want stupid answers like learn to bleed your brake better.
Edited by Laurence--Trials
how?
Because the seals are not made to work with water, and would most likely swell up and stop your brake from working. As was said previously as well, disc brakes heat up really quickly - especially the Mono Trial - so you'd run into issues with that almost straight away too, even if your brake actually worked long enough to do anything with it.
Either way - it doesn't work, it won't work, it will kill your brake, that's pretty much all you need to know...
last hollidays I had a problem with my front magura louise and the only chance that I had was bleed with water.
The feeling It's amazing and still works with water, the only thing that you don't have to do are long downhills.
But now I'm a little bit worried about my louise "life" and I have a can of Shimano mineral oil to refill it as soon as possible.
This is my experience.
For Hope it's another history because hopes use dot
Edited by 315r
The unleaded hoses are always the first hose you get to on the petrol stations around here, so I might put some petrol in my diesel car 'cos it's a bit easier.
:P
They just changed all the pumps at tesco here, the hoses are now in reverse and I did almost fill my car with diesel last night... >.<
