Trialerboy Posted September 20, 2010 Report Share Posted September 20, 2010 Can you fit a bash plate on a GU ST? Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted September 20, 2010 Report Share Posted September 20, 2010 Depends if it has mounts, is it a 20" or 26"? The 20" generally can fit a bashplate but I wouldn't recommend it because there's no real gusset so it'l have more chance of cracking. Quote Link to comment Share on other sites More sharing options...
Trialerboy Posted September 20, 2010 Author Report Share Posted September 20, 2010 Depends if it has mounts, is it a 20" or 26"? The 20" generally can fit a bashplate but I wouldn't recommend it because there's no real gusset so it'l have more chance of cracking. Its a 20" Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted September 20, 2010 Report Share Posted September 20, 2010 Should be able to run one then, personally i wouldn't, bashrings are more suitable really, lighter, do the same job and don't increase the chance of you frame cracking. Quote Link to comment Share on other sites More sharing options...
Trialerboy Posted September 20, 2010 Author Report Share Posted September 20, 2010 Should be able to run one then, personally i wouldn't, bashrings are more suitable really, lighter, do the same job and don't increase the chance of you frame cracking. I just found out it aint got a bashplate or fixings for one Quote Link to comment Share on other sites More sharing options...
woodman rider stanewell Posted September 23, 2010 Report Share Posted September 23, 2010 I had an gu st what model was it??? the disk versions have em but i thought all 20" gu's had miunts Quote Link to comment Share on other sites More sharing options...
Jamie2002 Posted September 23, 2010 Report Share Posted September 23, 2010 if the mounts are there you can fit it . cand you guys give me some votes i. need 5 votes to became a member Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted September 23, 2010 Report Share Posted September 23, 2010 if the mounts are there you can fit it . cand you guys give me some votes i. need 5 votes to became a member I would if your posts made sense, if your next 5 do I'll be happy to submit one Quote Link to comment Share on other sites More sharing options...
BlueSmokeyJoe Posted September 23, 2010 Report Share Posted September 23, 2010 i. need 5 votes to became a member Asking for validation is usually a means you wont get validated. You've mentioned it in nearly all of your posts. Just concentrate on making constructive well though out posts and you will have access to the full forum before you know it! Only trying to help you out here man. Quote Link to comment Share on other sites More sharing options...
