Small Question
trials owns
try using the tool on the top of chin as this is what i did and then any chain tool works
sweet, well i had a onza t bird and i changed it to a front freewheel and every since then i tension the chain nice but the brake pads are basically hitting the tyre and not set up square to the rim but when i move the wheel forward i dont have this problem but the chain is nice and lose.
Did you change the rear sprocket aswell? Not sure what youre front sprocket was but Im guessing as you say you swapped to FFW and your chain is now slack it was larger than 18t. You will need to change the rear sprocket to match the gear ratio, chances are you will need a 12t :)
yeah got a 12t on the rear and 18t freewheel on the front before it was something like 32t to rear freewheel.
18:12 is 1.5:1, to the same ratio then you would need a 27t front chainwheel. If you tell us exactly what size it was I can tell you what size rear sprocket you should have.
