Hs33 Brake Pad Squeel!
trials and error
That's not generally how it works, more noise more power is the usual case.
As the other guy said if you have onza citrus pads they'll squeak over noting, and its not a nice squeak.
EDIT: adding a brake booster often quietens the noise because there is less vibrations.
Edited by Jamie_Trials
what pads are they? onza citrus?
edit,
also make sure ur rim is very clean.
and if u don't know most pads are made to squeal for better braking performance.
How are pads made to squeal? the noice comes from a dirty rim a ground rim or a rim with tar on it!
I dont quite know how.. I guess they just push against the rim with alot of force and heat up and squeel, alot like basketball shoes when you drag 'em across the floor the rubber sole of the shoe does the same as a brake pad. Not 100% sure why they squeel though.
  • Like 1
So really its the wrong pad compound for the style of rim being used?!
I would not agree with that at all.
Won't a brake booster make the brakes stronger. Meaning I don't need to squeeze so hard??
Sort of, it will make the hold better.
a brake booster won't really help your arms, but it will stop the frame from flexing increasing the holding power of the brake. I have been using a Trialtech 2 bolt booster with great results.
If you havn't done already, bleeding the brake with water will help your arms.
