Zoo Vs Echo
Grant-MacD
personal preference to be honest.
technically same strenght as made from same material
few variants in echo frames and up until 09 there was only the python or pitbull - but now with the pirahna and the lynx - these frames are of lesser quality IMO - so i would just try and sample both frames in question and then choose - because no matter what someone tells you on here - your money buying and your the one who is riding the bike.
i have an 06 python and Effing love it - cant see me ever going/wanting to use a different frame - but thats just me
best of luck.
...but with different designs, so they aren't 'technically the same strength'. Should be pretty close though, although I'd reckon the Lynx is a bit stronger.
Sorta debatable again ;)
Out of the two, there's not really much in it. Gav has the Lite in long, and I had the Lynx in long and the two bikes don't really feel much different at all.
Then what?
As i said - Material is same - so same strength in material - I wasnt questioning the designs.
And this leads me to me justyfying why I said lesser quality,
Most of the welds I have seen on older zoo's (pythons) Compared to lynx's Seem Beefier and in my mind - Stronger
I love the Disc tab on Lynx frames - something in which echo held the advantage for me for a long time previously to the lynx's release.
But compared to my 06 python and lynx's i have sampled used with hs33/dengura - more signs of frame flex around the mounts
It is an endless debate - but as i mentioned previously its personel preference :)
You said "The frames are technically the same strength as they're made from the same material" - my point was that the design is different, which means they're not necessarily going to be the same strength. In much the same way you could make a frame out of that metal that was designed perfectly and worked incredibly well, but you could also make a frame out of that material that wasn't manufactured well and was fundamentally flawed in a design sense so it wouldn't be as strong.
EDIT: The welds also seem to be a lot higher quality on the Echo/Zoo frames than most other frames we sell.
