Maladie Posted September 19, 2010 Report Share Posted September 19, 2010 Hey there, i recently bought an Onza Pro 2010, and also an Echo SL freewheel to replace the Tensile 60 click it comes with. Though before i fit this freewheel, i was wondering whether it is in a good enough state to be fitted. If i shake the freewheel, only lightly too, then i can hear a quite noticable rattle. It sounded to me like a bearing or two was loose, so i took my SL to my local bike store, and asked them to look at it. They took it in, and rang me up the next day saying something like 'basically the only reason it's doing that is because it has no grease in it, and it will be fine to use how it is'. I said ok and took it back, but i'm still weary of the rattling. Can anyone here shed some light onto what's wrong with it, if anything? Cheers, James Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted September 19, 2010 Report Share Posted September 19, 2010 I've seen people saying this before and people like Onza-boy-mark just said its fine and stuff soo.. its fine Quote Link to comment Share on other sites More sharing options...
josh barker Posted September 19, 2010 Report Share Posted September 19, 2010 most freewheels do rattle, it should be normal. just run it and see if its ok Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted September 19, 2010 Report Share Posted September 19, 2010 it says on the tarty product page that they do rattle a little because of the bearing design, they're still fine to use Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 19, 2010 Report Share Posted September 19, 2010 These freewheels may appear to 'rattle' from new - this is down to the bearing system. It would be possible to add an extra bearing in and stop the rattle, however this would then cause the freewheel to lock up! If it's supermegaloose you can take a shim out from inside the freewheel, but unless you really, really need to I wouldn't recommend it. It'll be fine as it is. Quote Link to comment Share on other sites More sharing options...
Bronz Posted September 19, 2010 Report Share Posted September 19, 2010 I had the exact same worry. Bought an SL and it rattled, I took my old TR off and that rattled too, but ran perfectly well. Popped my SL on and all is well Quote Link to comment Share on other sites More sharing options...
Maladie Posted September 19, 2010 Author Report Share Posted September 19, 2010 Okay then, cheers everyone for your input Just needed to know really, didn't want to take any risks and f**k it up on the first ride. Quote Link to comment Share on other sites More sharing options...
