Slack Chain
Luke Dunstan
have a look at your axle and see if its sticking out the end of your frame slightly it could be that your bolts arnt actually clamping your frame enough
I see what you mean, but no that's not it.
Cheers.
EDIT:: Looked again its sticking out like 2-3mm, But if I take a link out the chain won't fit.
Edited by xDUNSTANx
Cheers.
if your axles sticking out then its never going to work and taking a link out wont help it, you need to either shorten your axle or put some spacers on the excess axle.
I think he thought you meant - as I did, for some reason - that "was it sticking out the end of the dropouts" as in, further back from the BB.
I know the sticking out the other way makes more sense, it just reads otherwise :P
