murph82 Posted September 17, 2010 Report Share Posted September 17, 2010 (edited) Hi any advice on the best way to spray my forks which are scratched to buggery and my rear gold anodised tryall rim which I bought because it was cheap but totally the wrong colour.......... wanna spray both black, can i just spray or will it need prepping a lot? thanks kevin Edited September 17, 2010 by murph82 Quote Link to comment Share on other sites More sharing options...
tubby Posted September 17, 2010 Report Share Posted September 17, 2010 (edited) sand all exisiting paint off the forks, using 180 grade sand paper. Then spray primer onto forks, once primers dry sand using 300 grade sand paper, then apply another coat of primer. Sand again using 400 grade paper and spray a few layers of paint, ensure each layers dry before applying the next. Don't go too mad with the paint. Primer and spray paint from halfords should be ideal. enjoy! Edited September 17, 2010 by tubby Quote Link to comment Share on other sites More sharing options...
murph82 Posted September 17, 2010 Author Report Share Posted September 17, 2010 sand all exisiting paint off the forks, using 180 grade sand paper. Then spray primer onto forks, once primers dry sand using 300 grade sand paper, then apply another coat of primer. Sand again using 400 grade paper and spray a few layers of paint, ensure each layers dry before applying the next. Don't go too mad with the paint. Primer and spray paint from halfords should be ideal. enjoy! cheers mate, i thought it'd be along those lines, laid up sick at the moment so plenty of time, should tidy the bike up! Quote Link to comment Share on other sites More sharing options...
