zaskar_gap Posted September 15, 2010 Report Share Posted September 15, 2010 just got my orders in from tarty, and i did order the right hand side of a complete echo sl brake lever. my question is, can i put a right side brake master on the left side??? the hose would be on top and the filler grub screw will be facing down ward....need an expert's advice!!! Quote Link to comment Share on other sites More sharing options...
superjay Posted September 15, 2010 Report Share Posted September 15, 2010 i cant say if it would work with an sl cause i have never used one but i did it with hs33 and it was fine Quote Link to comment Share on other sites More sharing options...
forteh Posted September 16, 2010 Report Share Posted September 16, 2010 It should work fine mounted upside down, you will need to make sure that the bleed screw is upmost when bleeding though Quote Link to comment Share on other sites More sharing options...
