Luke Dunstan Posted September 15, 2010 Report Share Posted September 15, 2010 As the description says, I've got 116 drop outs, but axle is about 1cm from the front. Is that okay or could it cause problems? Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted September 15, 2010 Report Share Posted September 15, 2010 As the description says, I've got 116 drop outs, but axle is about 1cm from the front. Is that okay or could it cause problems? Sorry, I may be able to help but I don't understand what you mean, can you explain better please? Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 15, 2010 Report Share Posted September 15, 2010 I'm assuming you mean you've got horizontal dropouts, and your axle's just sitting 10mm or so back from the further in it could be? If so, that's no problem at all. Very few frames actually work 'perfectly' in that sense. Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted September 15, 2010 Author Report Share Posted September 15, 2010 Sweeeet. My last 2 frames were fine. This one jast sat back alittle further than usual. Thanks Mark. Quote Link to comment Share on other sites More sharing options...
