Trialerboy Posted September 14, 2010 Report Share Posted September 14, 2010 Anyone got any tips for me on how to gap to front? Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted September 14, 2010 Report Share Posted September 14, 2010 Preload, kick, lean forwards gradually, press your front brake for your landing, when it reaches its peak let go and try pull your backwheel forwards. Going on an angle helps too. Quote Link to comment Share on other sites More sharing options...
Sprog! Posted September 14, 2010 Report Share Posted September 14, 2010 i learnt by not doing it to an object but finding a line or marking on the road and taking off where ever you are comfortable Quote Link to comment Share on other sites More sharing options...
bagre15 Posted September 19, 2010 Report Share Posted September 19, 2010 (edited) I would advise you to try it in a litle kerb and start with an angle to the kerb, so the chances of flipping forward are reduced. In the beggining it will be pretty scary, but with time you'll get used with the movement Edited September 19, 2010 by bagre15 Quote Link to comment Share on other sites More sharing options...
Danny Metcalfe Posted September 19, 2010 Report Share Posted September 19, 2010 Commitment. You need to commit yourself otherwise you'll never learn As mentioned, Start small - That way not a long way to fall just in case Third tip - Practise,practise,practise!! Godd luck Quote Link to comment Share on other sites More sharing options...
Stickyworm Posted September 19, 2010 Report Share Posted September 19, 2010 I started by sidehopping to front wheel, with the intent of staying on my front wheel. That got my body comfortable in the right position, then I gradually worked it around until I could do it straight on. Quote Link to comment Share on other sites More sharing options...
WIGAN ?? Posted September 19, 2010 Report Share Posted September 19, 2010 flat gapping to front is the hardest way to learn it, you need to be gapping upto something higer and not so far away probably just over a bike length then really commit to it or youl never pick it up, best thing to do is just get your weight right over the front as far as you can then worry about swapping after youv got that bit. Quote Link to comment Share on other sites More sharing options...
Trialerboy Posted September 20, 2010 Author Report Share Posted September 20, 2010 Thanks for all the tips. I will keep trying and hopefull get it soon. Quote Link to comment Share on other sites More sharing options...
