Help With New 26" Rear Wheel
stewart33
you'll want a wide rim, you can get custom wheels made on chain reaction so you can chose your hub, rim and other stuff, it depends if you running a freehub for a cassette or a screw on sprocket, maybe a dmr revolver for a screw on or a halo spin doctor, shimano xt for a freehub. It all depends how much you want to spend you can get cheap trials wheels on ebay like onza hogz but they don't come with disc adapters if needed. For a rim look at halo combats or anything else that takes your fancy but make sure they are pretty wide so you can run low pressure on you tyre
onza wheels
halo spin doctor
proberly best idea to go with a trials specific wheel like a echo tr they will be light and strong and not to expensive for a good wheel
echo tr
you could also get tarty to build a wheel up for you
Edited by Milo123
I like the Onza Pro Series. It is £68.09 at tartybikes.( http://www.tartybikes.co.uk/product.php?product_id=10563&category_id=25 ) I have been told that is is pretty durable. I say Tarty Bikes would be a good place to look for a rim. They have some good deals there.
Edited by John43
