Onza Vs Zona
Jimbob 2705
Which would you recommend out of a Onza T-Pro (I haven't found one yet but just say a standard 2nd hand one) or a Zona Zip?
The Zona Zip has the following :
- Zona Zip aluminium frame in silver
- Onza Muscleman cranks with bashguard
- Onza Hog rims
- Magura HS33 hydraulic rim brakes
- Onza forks
- Onza Creepy Crawler sticky tyres
It also has a Echo brake booster
Thanks
- Onza Hog rims
- Onza forks
Thanks
They are both similar as Zona and Onza are the same company, i would say the TPro :) but it depends on spec.
I have a Zona Zip and its longer than the T-Pro but lighter, its preference I would say...
If you want a short flicky bike, then the Onza is the way forward, but if you prefer abit of a longer bike then the Zona is the one to choose.
What spec is the Onza btw??
