dirt jumper jake Posted September 10, 2010 Report Share Posted September 10, 2010 reet, i got a 160mm caliper and a 180mm caliper. the 160mm caliper is just the shell, no pistons no seals nothing. i have a new seal kit for that, but how would i swap the pistons from the 180mm caliper to the 160mm? and also i have a sexy as f**k tech lever that i want to put on the mono trial caliper. is it all the same fittings as a 'normal' hope lever? cheers. Quote Link to comment Share on other sites More sharing options...
super Posted September 10, 2010 Report Share Posted September 10, 2010 Not a problem transfering pistons and seals from 160 to 1800mm caliper, check hope website for overhaul guide. I'm 99% sure all the new hope's use the same fittings so you should be able to use the lever without any probs. Worth checking the master cylinders are the same size in both levers so you know your going to get the power you want. Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted September 10, 2010 Author Report Share Posted September 10, 2010 Not a problem transfering pistons and seals from 160 to 1800mm caliper, check hope website for overhaul guide. I'm 99% sure all the new hope's use the same fittings so you should be able to use the lever without any probs. Worth checking the master cylinders are the same size in both levers so you know your going to get the power you want. Sweet exactly what i wanted to hear, cheers! Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted September 10, 2010 Report Share Posted September 10, 2010 It'll all go together sweet dude I'm 100% sure o that cos I have done it. Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted September 11, 2010 Author Report Share Posted September 11, 2010 It'll all go together sweet dude I'm 100% sure o that cos I have done it. Yeah i did it this afternoon, my front brake is mental now! Quote Link to comment Share on other sites More sharing options...
