t-comp-kierz Posted September 9, 2010 Report Share Posted September 9, 2010 I have a 04 maggie and i snapped my hose at the joint bit where it the hose goes into the lever. I was going to just cut it and put a new olive on it and put it back on. I have some spair olive for my newer model maggie. Are the olives the same size and do i just slide them on and put it all back together or do i actually need an olive? Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted September 9, 2010 Report Share Posted September 9, 2010 As far as I can remember you need to cut the tube, put on the shroud nut, put on new olive, poke it in the hole and do the shroud nut, make sure the tube is pushed all the way in and tighten it up. Bleed and go riding. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted September 9, 2010 Report Share Posted September 9, 2010 As far as I can remember you need to cut the tube, put on the shroud nut, put on new olive, poke it in the hole and do the shroud nut, make sure the tube is pushed all the way in and tighten it up. Bleed and go riding. ^ This... and yes the olive you have will fit the older lever Quote Link to comment Share on other sites More sharing options...
