tdubz Posted September 8, 2010 Report Share Posted September 8, 2010 recently got my ideal set up for a v brake avid sd7 tnn pads echo booster but somthing is happening that i dont understand the arms are able to move back and fourth on the lugs all the bolts are tight and the booster does not wobble threads are also fine on the lugs i dont know what to do but as you can imagine this sligh bit of "play" makes a noise as the arm taps and also a slight bit of movement within the brake which is the last thing i want how can i solve this thanks Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted September 9, 2010 Report Share Posted September 9, 2010 If you mean up and down movement on the lugs when the bolts are tight, I would consider a bit of movement here normal mine does it anyway and the bite and hold is amazing. Does your brake work fine? Quote Link to comment Share on other sites More sharing options...
