Magura 4 Bolt Mounts
SiTrials
Well chopped off the incorrectly mounted vee mounts today and welded on my 4 bolt mounts i got from tarty...
And all built up with a load of spares i've got.
Just need better forks/cranks/bars/stem/new front brake.
Time to mount some slicks and go to the skate park on it.
Were you able to set up the cylinders parallel to the rim? Cos you welded the mounts on parallel to the frame like / \
yeah I bolted an old cylinder with standard maggie pad to the steel mounts and held it against the rim, tacked them and welded them properly.
Looks more off than it is. and will fit a tryall rim in the back without offset mounts.
Hey at least they are in the right place now!! (Y)
probly sell it to be honest! but at least someone might buy it now. no one wanted it with vee mounts!!
