Billy-C Posted September 3, 2010 Report Share Posted September 3, 2010 Hayy guys I have just got a new Echo lite frame and a new Echo sl Standard headset. Now how do I fit the headset into the frame? Do I need a headset press or can I just use a hammer and tap it in? Can you guys help? thanks. Quote Link to comment Share on other sites More sharing options...
isitafox Posted September 3, 2010 Report Share Posted September 3, 2010 I do it with my dad but if your not too sure just take it to your local bike shop who should be able to do it on the spot for you! I put a block of wood on the bench, rest the bottom of the headtube on there flat, place the top cup in and hold it in place with another block of wood and tap it in by hitting the wood so your spreading the force out over the whole thing. If you get what I mean?! Quote Link to comment Share on other sites More sharing options...
trialsrider101 Posted September 3, 2010 Report Share Posted September 3, 2010 Very easy to do; 1. Place the cups just in the frame and no more (put a tiny bit of lubricant on if necessary). 2. Wedge the whole lot in a vice . 3. Slowly tighten the vice making sure that the cups go in evenly. 4. To minamalise scratching of the headset cups while in the vice use a couple of blocks of wood. I hope this is clear enough for you Tom Quote Link to comment Share on other sites More sharing options...
Billy-C Posted September 3, 2010 Author Report Share Posted September 3, 2010 I do it with my dad but if your not too sure just take it to your local bike shop who should be able to do it on the spot for you! I put a block of wood on the bench, rest the bottom of the headtube on there flat, place the top cup in and hold it in place with another block of wood and tap it in by hitting the wood so your spreading the force out over the whole thing. If you get what I mean?! Ohk thanks dude. Quote Link to comment Share on other sites More sharing options...
isitafox Posted September 3, 2010 Report Share Posted September 3, 2010 Oh yeah, then turn it over and do the other side, obviously. Quote Link to comment Share on other sites More sharing options...
Billy-C Posted September 3, 2010 Author Report Share Posted September 3, 2010 Very easy to do; 1. Place the cups just in the frame and no more (put a tiny bit of lubricant on if necessary). 2. Wedge the whole lot in a vice . 3. Slowly tighten the vice making sure that the cups go in evenly. 4. To minamalise scratching of the headset cups while in the vice use a couple of blocks of wood. I hope this is clear enough for you Tom Yea thanks thats really clear! thanks Quote Link to comment Share on other sites More sharing options...
