Kenny--Trials Posted September 1, 2010 Report Share Posted September 1, 2010 (edited) Hi guys, I just went to take my drive-side crank off when the remover tool fell off. I checked the threads and they are bare. How can i get the crank off? Thanks EDIT: By the way i run a square taper bb Edited September 1, 2010 by Kenny--Trials Quote Link to comment Share on other sites More sharing options...
trials owns Posted September 1, 2010 Report Share Posted September 1, 2010 so u striped your tread? try a chisel or something like that, wedge it between the cranks and bb and hit with a hammer, if that doesnt work try blow torching it and then do it.(might ruin the look of the crank) i had the same problem and it took friken ages and a lot of hard work. Quote Link to comment Share on other sites More sharing options...
trials owns Posted September 1, 2010 Report Share Posted September 1, 2010 Leave the bolt out and go and ride it up and down the street a few times, usually loosens them up a bit. oh yeah that first lol. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted September 1, 2010 Report Share Posted September 1, 2010 How the hell did you do that kenny? Have you got your new cranks? and if so what else did you get? Quote Link to comment Share on other sites More sharing options...
alex-trials-boy Posted September 1, 2010 Report Share Posted September 1, 2010 (edited) How the hell did you do that kenny? Have you got your new cranks? and if so what else did you get? He put the crank re-mover in and said it felt a little tight to screw in so I said "mabey you've crossed threaded it?" but he said it's always tight to screw in, so he used a spanner to tighten it and I noticed "swarf" (think that's how it's spelt) alu filings basicaly lol so I/we new the crank was threaded lol. He bought: neon c forks in silver whole front avid bb7 whole rear wheel build : viz hub monty rim ect heatsink coust pads in cnc backs And...... Laurence your on holiday in turkey stay of you pc u sad kid....!!!!! Edited September 1, 2010 by alex-trials-boy Quote Link to comment Share on other sites More sharing options...
Thurston Posted September 1, 2010 Report Share Posted September 1, 2010 Hit it with a hammer when the pedals in a down position, used to work a treat for me Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted September 1, 2010 Report Share Posted September 1, 2010 Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted September 2, 2010 Report Share Posted September 2, 2010 He put the crank re-mover in and said it felt a little tight to screw in so I said "mabey you've crossed threaded it?" but he said it's always tight to screw in, so he used a spanner to tighten it and I noticed "swarf" (think that's how it's spelt) alu filings basicaly lol so I/we new the crank was threaded lol. He bought: neon c forks in silver whole front avid bb7 whole rear wheel build : viz hub monty rim ect heatsink coust pads in cnc backs And...... Laurence your on holiday in turkey stay of you pc u sad kid....!!!!! Sounds decent, im guessing he threaded his old cranks.. Turky sucks balls! Would it be okay if when your at work on sunday i knocked for you and got my parts off your mum/dad or wouldn't they be awake? if not i dont serpose you could leave them round the back just by the gate? cause i wanna build them while your at work then i can play out about 11ish.. and check your pms / reply on pms so i dont have to spam kenny's topic. Quote Link to comment Share on other sites More sharing options...
Balls Deep trials team Posted September 3, 2010 Report Share Posted September 3, 2010 rubber hammer on the base of the crankarm on the inside whack it !! Quote Link to comment Share on other sites More sharing options...
Kenny--Trials Posted September 4, 2010 Author Report Share Posted September 4, 2010 Will it mess up my bottom bracket? Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted September 4, 2010 Report Share Posted September 4, 2010 Will it mess up my bottom bracket? Nope, a thin, big screwdriver lodged in between the crank and BB shell and whack it with a rubber mallet, should do the trick. Quote Link to comment Share on other sites More sharing options...
t-comp-kierz Posted September 4, 2010 Report Share Posted September 4, 2010 Hi guys, I just went to take my drive-side crank off when the remover tool fell off. I checked the threads and they are bare. How can i get the crank off? Thanks EDIT: By the way i run a square taper bb Get one of these (picture below) worked a treat for me Quote Link to comment Share on other sites More sharing options...
Kenny--Trials Posted September 4, 2010 Author Report Share Posted September 4, 2010 (edited) Nope, a thin, big screwdriver lodged in between the crank and BB shell and whack it with a rubber mallet, should do the trick. Thanks, this sounds a good idea. I dont want to get one of those tools because i would probably only use it twice. Edited September 4, 2010 by Kenny--Trials Quote Link to comment Share on other sites More sharing options...
Vortexor Posted September 4, 2010 Report Share Posted September 4, 2010 (edited) Get a peice of wood that fits perfect then hammer it with rubber mallet should come of with a few hits Don't have it shooting off Haha Edited September 4, 2010 by AndyyRider Quote Link to comment Share on other sites More sharing options...
dann2707 Posted September 4, 2010 Report Share Posted September 4, 2010 Use what's in the picture above. Had to use one of them for mine. So simple to use and works a treat. Quote Link to comment Share on other sites More sharing options...
