Hope Mono Trial
wonganut
  1. Fill resevoir.
  2. Pull and hold the lever.
  3. Crack the bleed nipple, the level in the resevoir should drop.
  4. Close the bleed nipple before the resevoir empties.
Repeat until you get oil coming from the bleed nipple, you may need to give it another bleed to ensure all the air is out :)
