LukasMcNeal Posted August 30, 2010 Report Share Posted August 30, 2010 Hey, I did try searching but the TF search done nothing! Basically what disc should I use to for a harsh grind? and what angle? Running a trialtech rim and heatsink yellows if it helps? Cheers lads Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted August 30, 2010 Report Share Posted August 30, 2010 i use a stone cutting disc at around 65 degrees 1 Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted August 30, 2010 Author Report Share Posted August 30, 2010 Is that a thick or thin disc? Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted August 30, 2010 Report Share Posted August 30, 2010 quite thin mate this is the one i use My link Quote Link to comment Share on other sites More sharing options...
MiuSliS Posted August 30, 2010 Report Share Posted August 30, 2010 I'd go metal cutting disc for a harsh grind. Quote Link to comment Share on other sites More sharing options...
Otacon Posted August 31, 2010 Report Share Posted August 31, 2010 Diamond Cutting disc bruth, razorrrrrrrrrrrrrrrrrrr sharp I'll sort you a grind when i go down to Tom's in brentwood if you want <3 you haha Quote Link to comment Share on other sites More sharing options...
forteh Posted August 31, 2010 Report Share Posted August 31, 2010 Personally for heatsink yellows I use a metal cutting disk, thinner is better but it doesnt matter so much as long as there is a square edge on the disk. Cant comment on using a harsh grind, but a medium/light (no pressure on the grind and at about 30 degrees from the rim surface) works perfectly for the yellows Quote Link to comment Share on other sites More sharing options...
ant Posted August 31, 2010 Report Share Posted August 31, 2010 i would watch this it may be helpful to you? http://www.tartybikes.co.uk/media.php?group=guides&id=2 1 Quote Link to comment Share on other sites More sharing options...
