aanderson Posted August 30, 2010 Report Share Posted August 30, 2010 Since I bought rear magura hs33 in late 2008 I've tried to use them filled with water ( which gives a good feel of the lever ) and antifreeze for more than half a year. After that I filled it with lubricant and it has never worked so bad. Pads are moving really slowly and changing the distance from the rim. One pad is closer to the rim and the other one - far away and vice versa. It's impossible to adjust them. So I've been thinking.. should I continue to experiment with filling my brakes with fluids such as water + windscreen washer concentrate, water + antifreeze, windscreen washer concentrate only etc. or should I get something similar to magura oil? Regards Quote Link to comment Share on other sites More sharing options...
Revolver Posted August 30, 2010 Report Share Posted August 30, 2010 Water and screenwash. Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted August 30, 2010 Report Share Posted August 30, 2010 Water and screenwash. +1 Quote Link to comment Share on other sites More sharing options...
