Doddsy2801 Posted August 30, 2010 Report Share Posted August 30, 2010 wondering what peoples feelings are on tyre pressures? whats a good standard pressure for everyday use? appreciate there will be suttle differences for type of terrain/weather conditions etc, but whats a good pressure for everyday riding? cheers for any replies. Quote Link to comment Share on other sites More sharing options...
trials owns Posted August 30, 2010 Report Share Posted August 30, 2010 depends on weight really, if you ride street it can be fairly hardish but can absorbs shocks without bursting. Quote Link to comment Share on other sites More sharing options...
Doddsy2801 Posted August 30, 2010 Author Report Share Posted August 30, 2010 depends on weight really, if you ride street it can be fairly hardish but can absorbs shocks without bursting. im around 13st mate,and ride mostly street? Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted August 30, 2010 Report Share Posted August 30, 2010 Damn its a small world we live in as i only live up the road from you in Plumstead Common. If your out and about later today, ill show you a few spots. Quote Link to comment Share on other sites More sharing options...
Doddsy2801 Posted August 30, 2010 Author Report Share Posted August 30, 2010 Damn its a small world we live in as i only live up the road from you in Plumstead Common. If your out and about later today, ill show you a few spots. next week sumtime deffinetly. bikes in tarty bikes gettin rebuilt atm, but ill msg you on here when i get here back. cheers. Quote Link to comment Share on other sites More sharing options...
wonganut Posted August 30, 2010 Report Share Posted August 30, 2010 20 in front and around 24 in the back Quote Link to comment Share on other sites More sharing options...
isitafox Posted August 30, 2010 Report Share Posted August 30, 2010 I run about 35psi on my mod Quote Link to comment Share on other sites More sharing options...
Doddsy2801 Posted August 30, 2010 Author Report Share Posted August 30, 2010 I run about 35psi on my mod yeah between 30-35 makes sense to me,cheers for the help. Quote Link to comment Share on other sites More sharing options...
ViZ_Burger Posted August 30, 2010 Report Share Posted August 30, 2010 It depends how good you are and how cofident you are on the back wheel . When i just started learning pedal hops what helped me ballence and grips was running at about 15 psi , But know ive got crank hops down i find ballence for attempts at sidehop hops easyer at about 25-30 psi . ive got a freind who runs his onza comp at abut 7 psi and hes just starting trials , of course this all changes when your on a stock Quote Link to comment Share on other sites More sharing options...
Doddsy2801 Posted August 30, 2010 Author Report Share Posted August 30, 2010 It depends how good you are and how cofident you are on the back wheel . When i just started learning pedal hops what helped me ballence and grips was running at about 15 psi , But know ive got crank hops down i find ballence for attempts at sidehop hops easyer at about 25-30 psi . ive got a freind who runs his onza comp at abut 7 psi and hes just starting trials , of course this all changes when your on a stock yeah point taken with pressures when your starting out, as im just gettin back into trials after a few years out im guna be rusty as hell, and even at my best im only average, 30psi ish is probably guna be a good place to start and work from there. Also guna run dual ply tyre on the rear which i never did before when i rode, so may poss be able to drop a few psi depending on the wall strength. cheers for the input. Quote Link to comment Share on other sites More sharing options...
MedwayRider Posted August 30, 2010 Report Share Posted August 30, 2010 Just Try a Couple and See Wt Your are Comfertable with Mate Quote Link to comment Share on other sites More sharing options...
