Bashring Spacer
Kenny--Trials
Hi Guys,
Ive just found the Try-All Sprocket/Freewheel Spacer which i had never seen before on tartybikes. I wanted to take my original onza t-pro bashring off but it acts a a spacer because the threads dont run all of the way down to the crank.
Could i use the try-all one or is it not made for that purpose? :blink:
Thanks
Description
- Alloy spacer from French manufacturers Try-All.
- Suitable for spacing out your freewheel or sprocket on both your cranks or on a threaded rear hub (e.g. to space out a screw-on sprocket).
- Available in silver only
Sounds like what it was made for ;)
EDIT: if you see alex tell him to pm me back or ill send a projectile poo at him.
Edited by Laurence--Trials
Hi Guys,
Thanks
Maybe it's worth a quick email or phone call to Tarty-Bikes, I'm sure they will help, although whether they are in today or tomorrow is debatable due to the bank holiday.
Hope I helped
James
