lowva96 Posted August 25, 2010 Report Share Posted August 25, 2010 when i crank forward on the right side it sorta clanks a little i think it could be the freewheel skipping could i have some advice please ? Quote Link to comment Share on other sites More sharing options...
Rockman Posted August 25, 2010 Report Share Posted August 25, 2010 when i crank forward on the right side it sorta clanks a little i think it could be the freewheel skipping could i have some advice please ? It sounds like it could be the bottom bracket, mine has worked loose I think and clicks when I push down hard on the pedals =/ Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted August 25, 2010 Report Share Posted August 25, 2010 Have you tightened the crank bolt? Pedals on tight? Quote Link to comment Share on other sites More sharing options...
pengsmelly Posted August 26, 2010 Report Share Posted August 26, 2010 sounds liek its either dry bearings or loose bearings in your bb, or could just be your crank is just loose. Best thing to do first is take crank off grease the axel of bb and around crank insert then do it up nice and tight. If the Problem carrys on then you will have to take the bb out grease all that up and check the bearings. Some times a bit pf grease can sort it all out. Unless your bearings have totally gone. Quote Link to comment Share on other sites More sharing options...
