trialsiain Posted August 25, 2010 Report Share Posted August 25, 2010 hi i have just got a brand new Zoo piranha frame and have my old cranks ( suntour duro isis) still, it has a 22 tooth sprocket and a fat bash ring.has anyone got any idea if this setup will work because i dont have enough money to buy new cranks yet sooo.......... will it work??? Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 25, 2010 Report Share Posted August 25, 2010 If you've got the frame, BB and cranks all at your disposal, you might as well just put it together to see if it fits? I'd imagine it's probably going to be pretty tight. I'm guessing they're square taper (?), so a lot of it will depend upon how tight you've had them done up before and whether the tapers are stretched on the cranks a bit... Quote Link to comment Share on other sites More sharing options...
trialsiain Posted August 25, 2010 Author Report Share Posted August 25, 2010 If you've got the frame, BB and cranks all at your disposal, you might as well just put it together to see if it fits? I'd imagine it's probably going to be pretty tight. I'm guessing they're square taper (?), so a lot of it will depend upon how tight you've had them done up before and whether the tapers are stretched on the cranks a bit... hi thanks for the fast reply its an isis bb Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 25, 2010 Report Share Posted August 25, 2010 128mm? Quote Link to comment Share on other sites More sharing options...
trialsiain Posted August 25, 2010 Author Report Share Posted August 25, 2010 128mm? no i dont think so m8 Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 25, 2010 Report Share Posted August 25, 2010 Pretty unlikely then I'd imagine... Quote Link to comment Share on other sites More sharing options...
