dannytrialskid Posted August 25, 2010 Report Share Posted August 25, 2010 (edited) HI, When I get the Rockman Alkali I will need a 127.5mm Bottom Bracket. I think that mine is 123.5mm so obviously it's too small, either my cranks will just miss the frame or they will hit. My friend said that some guy called 'James Butcher' used spacers to make it work, instead of buying a bigger BB. Would this work? I don't see how it would? Danny. EDIT: Just noticed I made a new thread for this when I could of posted in other topic, my bad! Edited August 25, 2010 by dannytrialskid Quote Link to comment Share on other sites More sharing options...
Juan Manuel Posted August 25, 2010 Report Share Posted August 25, 2010 (edited) ISIS or square tapper?? Anyways placing a spacer between the crank and the bottom bracket stop may cause the crank coming loose as the BB has a "conic" shape, then its thiner at the end of the axle. I don't know if you understand what I mean Edited August 25, 2010 by Juan Manuel Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted August 25, 2010 Author Report Share Posted August 25, 2010 ISIS or square tapper?? Anyways placing a spacer between the crank and the bottom bracket stop may cause the crank coming loose as the BB has a "conic" shape, then its thiner at the end of the axle. I don't know if you understand what I mean ISIS, and that's what I thought, that the crank would come loose. Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 25, 2010 Report Share Posted August 25, 2010 Didn't he have a 128mm BB in his to begin with though? Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted August 25, 2010 Author Report Share Posted August 25, 2010 Didn't he have a 128mm BB in his to begin with though? I have no idea, I don't even know the guy. Quote Link to comment Share on other sites More sharing options...
