dlak Posted August 24, 2010 Report Share Posted August 24, 2010 Hello, I own an onza bird 09 with 180mm cable front disc. It also has magura mounts at the front. Is it a worthy upgrade to switch to hs33s front and rear? The rear is v mount only so I understand that I,ll need the evolution mounts there. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted August 24, 2010 Report Share Posted August 24, 2010 i would just upgrade your rear vee to something better along with the cable and lever, they are just as good as hs33. and for the front just set the disc up perfect and you will be fine Quote Link to comment Share on other sites More sharing options...
