Gaz96 Posted August 23, 2010 Report Share Posted August 23, 2010 The TPA on my front brake wont move, will buying a new lever of tartybikes fix this? Quote Link to comment Share on other sites More sharing options...
trialsiain Posted August 23, 2010 Report Share Posted August 23, 2010 The TPA on my front brake wont move, will buying a new lever of tartybikes fix this? hi gaz dont bother buying a new lever your tpa has either cross threaded or is stripped. you should buy a tpa wheel and pin set for £4 on tartybikes..its on brake spares Quote Link to comment Share on other sites More sharing options...
Gaz96 Posted August 23, 2010 Author Report Share Posted August 23, 2010 Thanks, how do i fit these and take out the old ones. Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted August 23, 2010 Report Share Posted August 23, 2010 Use common sense and have a go.. Quote Link to comment Share on other sites More sharing options...
theom Posted August 23, 2010 Report Share Posted August 23, 2010 (edited) If its the plastic one you could just clamp it in a vice then rip it out, Then just screw the metal wheel on. Edited August 23, 2010 by theom Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted September 7, 2010 Report Share Posted September 7, 2010 on my old t-pro the tpa broke so i cut to length a bolt and filed two sides flat so it fitted in the lever and used a bolt to screw it in to the lever, its a bodge job and starts to wear away the plastic casings but it works just so you aren't without a bike while your waiting for your replacement Quote Link to comment Share on other sites More sharing options...
