Bike Troubles
Kenny--Trials
Hi guys,
To cut a long story short, I was pulling my wheel back to tighten my chain. It was nearly perfect, not too loose, not too tight.
I then went to pedal kick and I heard a massive 'KLONK' and my chain was loose again but by bolts on my rear wheel were tight. I did get a new chain but I thought it had already bedded in. I also got a new echo sl freewheel two weeks ago but hasnt skipped once till today where it has skipped 5 times.
Please help. (N)
That's impossible in that they were all retained by the factory.
If your wheel's slipped forwards and your chain's loose, then it's pretty easy for your chain to skip over the teeth of your sprocket. Because of that I'd imagine it's more your chain jumping on your sprocket rather than the freewheel itself skipping. Could be wrong though!
If you put a spacer under the head of the snail cam bolt you can effectively make the bolt bigger. If you're running smooth snail cams it may also be worth upgrading to toothed ones.
Andy - seems strange that you need to do that much messing around with your Lynx. With 18:12 on mine, I could use a set of TR cams with no problems at all...
See kenny i said that the chain was loose it slipped over the freewheel you chain could move bout 3-4CM up nd down so it had loads of movement to slip over the freewheel :)
Does anyone have any experiences with the trial-tech chain tugs?
I was getting a bit p"#%ed of with snail cams anyway
