stolen bmx ltd Posted August 18, 2010 Report Share Posted August 18, 2010 i bought this new bmx today and after about an hour of riding it the crank started to make a wierd noise everytime i peddled , will this noise go away and what is it ? Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted August 18, 2010 Report Share Posted August 18, 2010 Wrong forum? Tighten the crank. Tighten the BB. Tighten the pedal. Quote Link to comment Share on other sites More sharing options...
stolen bmx ltd Posted August 18, 2010 Author Report Share Posted August 18, 2010 On 8/18/2010 at 1:50 AM, Ben John-Hynes said: Wrong forum? Tighten the crank. Tighten the BB. Tighten the pedal. okay ill try but they are factory fitted cranks and are really tight anyway do you know if it will go away? Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted August 18, 2010 Report Share Posted August 18, 2010 Not if you just leave it, no. Just think about it... Quote Link to comment Share on other sites More sharing options...
stolen bmx ltd Posted August 18, 2010 Author Report Share Posted August 18, 2010 all the pedals and crank is all tight but the noise is still there does that mean its broke? Quote Link to comment Share on other sites More sharing options...
Alexthelyons Posted August 18, 2010 Report Share Posted August 18, 2010 What kind of noise is it? Does it only happen at a certain point? Quote Link to comment Share on other sites More sharing options...
josh barker Posted August 18, 2010 Report Share Posted August 18, 2010 try the bmx forum?? sounds like its either the bearings in your bottom bracket or pedals Quote Link to comment Share on other sites More sharing options...
stolen bmx ltd Posted August 18, 2010 Author Report Share Posted August 18, 2010 On 8/18/2010 at 10:25 AM, Alexthelyons said: What kind of noise is it? Does it only happen at a certain point? It's like a loud clicking noise and yeah it does only happen at a certain point Quote Link to comment Share on other sites More sharing options...
Dwarf Shortage Posted August 18, 2010 Report Share Posted August 18, 2010 Take your cranks out, grease 'em up, and do the same to your bb and pedal threads. If that doesn't sort it, post here http://www.bmx-forum.co.uk/forum/ Quote Link to comment Share on other sites More sharing options...
Alexthelyons Posted August 18, 2010 Report Share Posted August 18, 2010 From my experiance, new bearings. Bmx forum isn't that great, it's full of dicks that give new people loads of shit then complain you didn't search even if you do. Quote Link to comment Share on other sites More sharing options...
stolen bmx ltd Posted August 18, 2010 Author Report Share Posted August 18, 2010 On 8/18/2010 at 4:22 PM, Alexthelyons said: From my experiance, new bearings. Bmx forum isn't that great, it's full of dicks that give new people loads of shit then complain you didn't search even if you do. So do you think the noise will go after a while because there new bearings ? Quote Link to comment Share on other sites More sharing options...
jake-clements Posted August 19, 2010 Report Share Posted August 19, 2010 On 8/18/2010 at 9:00 PM, stolen bmx ltd said: So do you think the noise will go after a while because there new bearings ? yes, the noise should go away mate, its just becaue its new and everything is wearing in, if it doesnt go away after being rdden for a week or so then take out your bottom bracket and grease it hope this helps. Quote Link to comment Share on other sites More sharing options...
Leistonbmx Posted August 19, 2010 Report Share Posted August 19, 2010 When buying a new bike you should check all the bolts and grease everything. They're only assembled in a factory so they aren't all checked perfect. As for bmx forum, lol. Its the same as this forum. Quote Link to comment Share on other sites More sharing options...
TROYston Posted August 20, 2010 Report Share Posted August 20, 2010 Did you even use the search bar? Quote Link to comment Share on other sites More sharing options...
Peter221ti Posted August 21, 2010 Report Share Posted August 21, 2010 sometimes the sprocket on brand new bmx bikes is not seated properly against the crank and so as you pedal the chain doesn't engage properly making a click. Check its runs true hope that helped Quote Link to comment Share on other sites More sharing options...
montyFORlife Posted August 21, 2010 Report Share Posted August 21, 2010 On 8/18/2010 at 1:49 AM, stolen bmx ltd said: i bought this new bmx today and after about an hour of riding it the crank started to make a wierd noise everytime i peddled , will this noise go away and what is it ? if its only at a certain point it could be a a craked bearing Quote Link to comment Share on other sites More sharing options...
