trails4lif3 Posted August 16, 2010 Report Share Posted August 16, 2010 Hello every one. I need every one's rewis on the the hope pro 2 trials hub. I realy cant decide would it fit on two a 19 rear wheel ?? Thanks every one Kieran. Quote Link to comment Share on other sites More sharing options...
Revolver Posted August 16, 2010 Report Share Posted August 16, 2010 It wouldn't work at all. 19" wheels are made for mod frames. Mod frames take rear hubs that are 116mm wide. Hope pro II hubs are 135mm wide. Now, if you want my 'rewis' of a hope pro II trials - it's outstanding, and if you break it, hope seem to be more than happy to fix it or replace it for you. 1 Quote Link to comment Share on other sites More sharing options...
trails4lif3 Posted August 16, 2010 Author Report Share Posted August 16, 2010 It wouldn't work at all. 19" wheels are made for mod frames. Mod frames take rear hubs that are 116mm wide. Hope pro II hubs are 135mm wide. Now, if you want my 'rewis' of a hope pro II trials - it's outstanding, and if you break it, hope seem to be more than happy to fix it or replace it for you. Thank you verry much for the advice. Quote Link to comment Share on other sites More sharing options...
Alexthelyons Posted August 17, 2010 Report Share Posted August 17, 2010 Thanks aswell, I didn't know mod frames took 116mm hubs Quote Link to comment Share on other sites More sharing options...
TROYston Posted August 18, 2010 Report Share Posted August 18, 2010 Unless you have an Atomz or another mod frame that has a 135 rear end. Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted August 18, 2010 Report Share Posted August 18, 2010 Unless you have an Atomz or another mod frame that has a 135 rear end. No? No mod frames have 135mm dropouts. Quote Link to comment Share on other sites More sharing options...
joea Posted August 18, 2010 Report Share Posted August 18, 2010 it would work but you will need to cut the axle and the driver down danny swindlehursthad one on his 19 wheel hope that helps you mate Quote Link to comment Share on other sites More sharing options...
Revolver Posted August 18, 2010 Report Share Posted August 18, 2010 (edited) No? No mod frames have 135mm dropouts. I think the Atmoz Premier does actually have 135mm dropouts. It's like the only one though. It has vertical dropouts and its own built in tensioner, does it ring a bell? http://www.tartybikes.co.uk/product.php?product_id=10882&category_id=10 It's that one. it would work but you will need to cut the axle and the driver down danny swindlehursthad one on his 19 wheel hope that helps you mate It's such a faff though, it's not worth the effort. Edited August 18, 2010 by Revolver Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted August 18, 2010 Report Share Posted August 18, 2010 hope that helps you mate MOST unhelpful post ever. Quote Link to comment Share on other sites More sharing options...
TROYston Posted August 19, 2010 Report Share Posted August 19, 2010 Yuo can also get marino to make you a mod with a 135 rear end. Quote Link to comment Share on other sites More sharing options...
Dan Clark Posted August 19, 2010 Report Share Posted August 19, 2010 Brisa B20D's had a 135mm rear end too Quote Link to comment Share on other sites More sharing options...
