Chain Tensioner Problem
Jackk-08
I think I have a problem with my chain tensioner. I dont know whether it is just because its a crap one or ive done something wrong. Its a fixed trialtech chain tension from tarty bikes.
I tension my chain so the chain has about half an inch play up and down because anymore than that and my chain rubs on my frame =/
But when ever I seem to do a big pulse hop there is a massive "twang" like the chain tensioner is slipping on its bolts and thn chain goes slacker and slacker.
I had a look at sprung chain tensionors, are they any better? is it something ive done rather than the tensioner itself?
Here is a picture of my set up
  On 8/18/2010 at 4:45 PM, WIGAN ?? said:
solong as its keeping the tension yeah sounds fine have you tried putting a bit more tension on the spring ?
No how could i do that?
The arm even moves when i touch it though haha thats why i thought it was wrong. you the bit that has tensile written on it haha
  On 8/18/2010 at 4:53 PM, WIGAN ?? said:
nahh thats not right then, sounds like youv stripped the threads on your mech then so you need a new one or you can bolt it directly onto your axle like i have wich personally i think is better
yeah possbily but its a 3 day old mech bracket and my axle bolts are alot small that the bolt for the chain tensioner! =/ Thanks for you help thougt mate ill go have another look
  • 2 weeks later...
