04 Magura Tpa Replacement
Kenny--Trials
Take off the lever blade and the red plastic thing, then remove the bit inside the lever blade thats snapped and stick a M5 bolt through the threaded hole on the adjuster where the red bit was, job done. You can be fancy and grind a slot in it so it's the same as the old one, but it works perfectly fine as just a bolt.
It hasn't snapped its just when i try to move it left and right it doesn't work
