modifiedridah2k9 Posted August 13, 2010 Report Share Posted August 13, 2010 Easy, Quick one here, what length do M6 4-Bolt brake booster bolts need to be? M6 x ?? Is M6 x 60 the right size? Cheers. Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted August 13, 2010 Report Share Posted August 13, 2010 look in the bolt section on tarty... and look in the description of the bolts... it will tell you what they are to be used for Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted August 13, 2010 Report Share Posted August 13, 2010 Easy, Quick one here, what length do M6 4-Bolt brake booster bolts need to be? M6 x ?? Is M6 x 60 the right size? Cheers. Is it not M5 bolts? and its M5 x 45 i think. Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted August 13, 2010 Author Report Share Posted August 13, 2010 Is it not M5 bolts? and its M5 x 45 i think. Its for my mate, and his brake just got helicoiled, so its been drilled, tapped or whatever to M6 size. Quote Link to comment Share on other sites More sharing options...
Revolver Posted August 13, 2010 Report Share Posted August 13, 2010 Its for my mate, and his brake just got helicoiled, so its been drilled, tapped or whatever to M6 size. Hold on... If his brake was helicoiled it would be m5, unless it was done wrong. Helicoil doesn't mean stripped. Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted August 13, 2010 Author Report Share Posted August 13, 2010 Hold on... If his brake was helicoiled it would be m5, unless it was done wrong. Helicoil doesn't mean stripped. Oh? I dont know, its deffinitly 1 size up from normal size. I dont really know though it aint mine lol. Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted August 13, 2010 Report Share Posted August 13, 2010 When you heli something you drill it out to M6 and put a insert in to take it back to M5. Quote Link to comment Share on other sites More sharing options...
