Matt Vandart Posted August 13, 2010 Report Share Posted August 13, 2010 Do you bother to 'toe in' your pads on your trials bike? If so, does it make difference? Front AND back? Thanks Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 13, 2010 Report Share Posted August 13, 2010 Usually makes them quieter, but makes the lever feel a bit meh. Just set them up with as low spring tension as possible, lube the cables, experience win. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted August 13, 2010 Author Report Share Posted August 13, 2010 Flat on the rim I take it. Thanks Mark Quote Link to comment Share on other sites More sharing options...
jambo Posted August 13, 2010 Report Share Posted August 13, 2010 i sometimes, if they are sitting a little of just for speed just pop the spring out give it wee bend just to pull it over a bit to get the pad spacing spot on, Apart from that i dont touch the screws at all, make sure your cable routing is spot on to makes it a little lighter with less bends. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted August 14, 2010 Author Report Share Posted August 14, 2010 Usually makes them quieter, but makes the lever feel a bit meh. Just set them up with as low spring tension as possible, lube the cables, experience win. Today I experienced win. Quote Link to comment Share on other sites More sharing options...
