trails4lif3 Posted August 12, 2010 Report Share Posted August 12, 2010 hiii every one i have bean haveing alot of problems with puntchers recently has any one got any ideas how to get rid of puntchers or get less of them???? Quote Link to comment Share on other sites More sharing options...
stya_bear Posted August 12, 2010 Report Share Posted August 12, 2010 Higher pressures, thicker walled tyres, smoother riding? Quote Link to comment Share on other sites More sharing options...
angua Posted August 12, 2010 Report Share Posted August 12, 2010 Higher pressures, thicker walled tyres, smoother riding? +1(Y) Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted August 12, 2010 Report Share Posted August 12, 2010 Talcum powder, lots of it. Quote Link to comment Share on other sites More sharing options...
Alister Burt Posted August 13, 2010 Report Share Posted August 13, 2010 I ride unicycles, but I used to get a lot of pinch flats on my creepy crawler. I found that wrapping my inner tube up in a spare inner tube helped a lot, as well as upping the pressure. If you aren't too concerned about weight, I also know a few people who run 16 inch MX tubes in their tyres who have very little trouble Quote Link to comment Share on other sites More sharing options...
N.Wood Posted August 13, 2010 Report Share Posted August 13, 2010 Just so you know, its spelt 'puncture'. As in 'to puncture a woman's hymen' Quote Link to comment Share on other sites More sharing options...
JD™ Posted August 13, 2010 Report Share Posted August 13, 2010 Just so you know, its spelt 'puncture'. As in 'to puncture a woman's hymen' Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted August 13, 2010 Report Share Posted August 13, 2010 Just so you know, its spelt 'puncture'. As in 'to puncture a woman's hymen' Sig'd Quote Link to comment Share on other sites More sharing options...
Balls Deep trials team Posted August 13, 2010 Report Share Posted August 13, 2010 I ride unicycles, but I used to get a lot of pinch flats on my creepy crawler. I found that wrapping my inner tube up in a spare inner tube helped a lot, as well as upping the pressure. If you aren't too concerned about weight, I also know a few people who run 16 inch MX tubes in their tyres who have very little trouble thats what i doo helps alot Quote Link to comment Share on other sites More sharing options...
Kenny--Trials Posted August 13, 2010 Report Share Posted August 13, 2010 What innertube are you riding? This has a big effect on when you get punctures, try riding a thicker one, if your not worried about weight. Also where you ride. If you ride where there is lots of thorns of corse you are going to get punctures. Hope this helped. Quote Link to comment Share on other sites More sharing options...
Alexthelyons Posted August 14, 2010 Report Share Posted August 14, 2010 What some bmxers do (it might be differant for trial riders) is wrap electrical take around your rim, so it covers the spoke nipples. This might be differant for trial riders as I've only seen it done on bmx. Quote Link to comment Share on other sites More sharing options...
Alister Burt Posted August 14, 2010 Report Share Posted August 14, 2010 What some bmxers do (it might be differant for trial riders) is wrap electrical take around your rim, so it covers the spoke nipples. This might be differant for trial riders as I've only seen it done on bmx. Most trials rims are drilled to save weight, so there is a strip of tape going around the rim anyway (the rim tape) Quote Link to comment Share on other sites More sharing options...
trails4lif3 Posted August 15, 2010 Author Report Share Posted August 15, 2010 What innertube are you riding? This has a big effect on when you get punctures, try riding a thicker one, if your not worried about weight. Also where you ride. If you ride where there is lots of thorns of corse you are going to get punctures. Hope this helped. thanks i ride all street thats what i doo helps alot thanks n im not worried about wieght soo i will investgate tht Quote Link to comment Share on other sites More sharing options...
tubby Posted August 16, 2010 Report Share Posted August 16, 2010 (edited) if you're riding 26" try a downhill inner tube, their thicker and designed to take more abuse than your 'average' tube. Edited August 16, 2010 by tubby Quote Link to comment Share on other sites More sharing options...
trails4lif3 Posted August 16, 2010 Author Report Share Posted August 16, 2010 if you're riding 26" try a downhill inner tube, their thicker and designed to take more abuse than your 'average' tube. thanks for the advice but i ride 20" Quote Link to comment Share on other sites More sharing options...
Alexthelyons Posted August 17, 2010 Report Share Posted August 17, 2010 thanks for the advice but i ride 20" Your profile says you ride a stock? Quote Link to comment Share on other sites More sharing options...
trails4lif3 Posted August 17, 2010 Author Report Share Posted August 17, 2010 Your profile says you ride a stock? Yh i do ride a stock 20". Quote Link to comment Share on other sites More sharing options...
Revolver Posted August 17, 2010 Report Share Posted August 17, 2010 Stock means 26" bike Mod means 20" bike. You ride a mod. Even if it is standard spec, or stock, it is a mod. Quote Link to comment Share on other sites More sharing options...
trails4lif3 Posted August 29, 2010 Author Report Share Posted August 29, 2010 Stock means 26" bike Mod means 20" bike. You ride a mod. Even if it is standard spec, or stock, it is a mod. thanks for tht Quote Link to comment Share on other sites More sharing options...
colesie Posted August 29, 2010 Report Share Posted August 29, 2010 are the punctures pinch flats, or items penetrating the tyre? if pinch flates, as already said, stick a tad more pressure in, or consider replacing the tyre, if its thorns etc, try the panaracer kevlar strips, work well at reinforcing the rubber! Quote Link to comment Share on other sites More sharing options...
ViZ_Burger Posted August 30, 2010 Report Share Posted August 30, 2010 I used to get this problem alot and would get snake bite puntctures every other day. for know just carry a repair kit and minipump around in a bag . But i found the cause , I was using a starnderd bmx tube in a 19" by 2.5" back creepy crawler , This causes the tube walls to expand to have to reach the sidewalls of the tyre and therfore the tube will stretch and the walls of the tube will get thinner and puncture ALOT . there are 2 things that can be done to sort it out . 1 run the tyre at higher pressure and you wont get so many pinch flats but one day will explode , And the second one is get a proper trials tube and you can run at whatever pressure you wish and have no problems atall . well unless you do roll over alot of thorns hope this hellped Quote Link to comment Share on other sites More sharing options...
JamT Posted August 31, 2010 Report Share Posted August 31, 2010 just get a kenda, you won't regret it even if they are £7 Quote Link to comment Share on other sites More sharing options...
Kenny--Trials Posted August 31, 2010 Report Share Posted August 31, 2010 Are you a weight weenie?? If your not then get the kenda downhill. Beast of an innertube. Quote Link to comment Share on other sites More sharing options...
