Kieran@ZSClothing Posted August 12, 2010 Report Share Posted August 12, 2010 chould i i get a pair of trial techs to work with a sloped stem? because it has the threads inside it could you just put a star nut thingy in it ? http://www.tartybikes.co.uk/images/forks/large_ttforktopcap.jpg Quote Link to comment Share on other sites More sharing options...
WIGAN ?? Posted August 12, 2010 Report Share Posted August 12, 2010 yeah itl work i used a starnut on my viz ones cos i lost the threaded topcap, works but it nackers the threads in the forks Quote Link to comment Share on other sites More sharing options...
N.Wood Posted August 12, 2010 Report Share Posted August 12, 2010 Bear with me on this Kieran... Right if you get the Trialtech threaded topcap and cut off the mushroom/topcap bit you're left with a threaded tube. If you get a little nut the right size for a topcap bolt, it'll slip tight in the bottom of this tube and be held there by a little lip. You can then screw that lot into the forks till its flush, then put a bolt and topcap through like normal and jobs a goodun. Knowledge courtesy of Mr Adam Read. Worked real well with my Try-all stem, and now use it instead of the threaded topcap with my King headset. Quote Link to comment Share on other sites More sharing options...
